Need X-Over Settings For Peavey QW System.
Hey all. The settings I had gotten from this site for my last system worked so well I had to ask for your help again. Here is the new system.
(2) Peavey QW1 Dual 10\" with Horns (Tops)
Frequency response: 200 Hz to 18 kHz
Power handling: 600 watts continuous, 1200 program, and 2400 peak
(2) Peavey QW218 Dual 18\" (Subs)
Frequency response: 47Hz-1.5kHz+/- 3dB anechoic, 40Hz-1.5kHz half space+/- 3dB
Power handling: 1600 Watts continuous, 3200 program, 6400 peak
Each Top has it's own Peavey GPS3500 running 3500 watts @ 4ohms bridged
Each Sub has it's own Peavey CS4080 running 4080 watts @ 8ohms bridged
In the months to come I will have another amp to tri-amp the system and put seperate power into the highs' but this is it for now.
I am using a Driverack PA for my FOH and another unit for my monitors.
We've got way more power than we'll ever use, but it's exciting because I've NEVER been able to say that before!
But on that note also, do I have too much power going into the tops here? I like the headroom but I also don't want to damage our investment.
Thanks so much for your time and help guys.
Ok, supposing you can make the subs work in that range without sounding HONKY...and I assume that the 120 to 170 hz are will need some serious PEQ work...here is what I would do...
You didn't specify a platform...so...
HPF 35hz BW 18...
LPF 200 hz LR24
HPF 200 hz (or find a small frequency spread...)
You will likely need a PEQ for the xover point as well...since the tops are 3db down @ 200 hz...
If it were me I would have added a lo mid...like the speaker I added to the FAQ section as a DIY project... then you would have a SUPERB system! one that could really knock your fillings loose...
What kind of filter should I use to roll of the subs at around 180hz?
And, am I putting too much power into my tops, risking damaging them?
Well, keep us informed...
good luck
Power handling:
Mid Section: 600 watts continuous, 1200 program, and 2400 peak
High Section: 100 watts continuous, 200 program, and 400 peak
Each Dual 10\" Drivers get its own GPS3500 running 3500 watts @ 4ohms bridged mono
The (2) Compression Drivers will now share a PV2600 running 550 watts per channel @ 8ohms stereo
It was late and had to get them up and running, so what I did Gadget, was LPF the Mids at 1.12KHz, with a LR24. The Highs were HPF at 1.18 (LR24).
I set the inputs on all my amps using these crossover points, and seemed to sound ok at a low volume after a quick RTA (it was 1am and we were in the garage)
So I'm going to gig tonight and run with these settings, unless I see that you post something to the contrary.
I'm also gonna work on the low/mid point with some EQ once I get it set up and can listen to it at volume tonight.
Gadget, thanks for all your help and direction, you're a real asset to this forum.
Balancing the horns and 10's won't be too difficult...Then when you get real frisky, use the pre crossover delay to back the system up to the loudest thing in the backline... usually the guitars or bass or... in my case the Kick monitor.
My specs from Peavey read like this...
Time Offset:
Mid Frequency: o ms
High Frequency: o.813 ms
So...what I'm understanding here is I'm going to add 8.313 ms of delay to my Highs (Peavy's 0.813 + the 7.5 from the LR24), and 7.5 ms of delay to my mids still compensating for the LR24.
This is what I'll do tonight.
I'll check back before I leave to see if you've confirmed this.
Thank you so much once again for your direction.
P.S. - I read in a previous post you asked for opinions on doing Driverack sessions/seminars. Guitar Center aside, I'd be willing to bet many medium to large music stores would look to aquire you're services as a marketing tool to help sell Driveracks. I'm not sure if you'd make a fortune, but you'd prob be able to visit quite a few cities across the country on someone elses corporate dime.
hi's 7.5 ms +.813ms
mids 7.5 ms
Good luck.. let us know..
The amount of headroom is off the charts for me. I don't think we'll ever have this system breathing heavy. I mean, this thing will do 700 people in a club while twiddling it's thumbs.
I've never been a huge fan of Peavey, but with this QW line, they've really outdone themselves. Being in the price range of EAW LA Series, JBL SRX 700 Series, and EV QRX Series (I've used all these cabs), I'd say they come out on top. The vocals sounded better than with the EV QRX212!!!! (which I've always personally considered to be the best sounding club venue vocal box available)
The only drawback is the weight and size, but they're worth it.
I'm gonna try to get to setting up a stack outside this week to tune 'em flat, which I haven't had the chance to do yet, and I'll have a better canvas to work with next time out.
Gadget you're right, they do need a little work in the 200Hz range, but I have the subs LPF at 160, so I have a little separation and I'm kinda digging the room down there.
Thanks again for all your help.
