Using PA for Monitor Mix
As stated in my last post. I have recently upgraded my PA system to powered speakers and the driverack PX. I have been using my Driverack PA on my monitor mix by using the mid outputs but am wondering, does the PA provide the capability to make all of the outputs full range to provide a better monitor mix?
I see that section 2.5 \"Navigating the Xover Section\", says that I'm able to edit the parameters of the crossover but I'm not in front of my unit right now and wanted to know if indeed I'd be able to edit each of them considerably. Preferably 80Hz to 20kHz.
hum :?
Could not connect to smtp host : 10060 : A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
DEBUG MODE
Line : 111
File : smtp.php
This is a PX 2X4 is the best you can do and yes, filters can be set for all or part of the frequency spectrum, simply set the HPF where you want it.
But if you could set up a 2x6, that would be way cool. 8)
Gadget, got an answer for me on my 260 output problem?
Ran into problems sending Mail. Response: 500 5.3.3 Unrecognized command
DEBUG MODE
Line : 122
File : smtp.php
I can post fine, but replies give me these crazy errors (even though they post).
I think they are working the bugs out of the new server...
