Custom speaker xover setting
Driverack pro PA.
How do I take the settings I have for a speaker and translate that in the xover section for a custom speaker. For example do I use BW18 or LR24 and how do I know? We are using a custom biamp and the low are MTX speakers with the following specs:
Diameter of Subwoofer (2) 15\"
Type Full Range
Frequency Range
(-10dB) 36Hz-20kHz
Nominal Impedance 4 ohm
Sensitivity 96dB
Power Handling (watts) 300 RMS/1200 Total
Crossover Frequency 2.5kHz
Maximum Peak SPL 127dB
I have tried taking the 260 GUI and loading the speaker config and then looking at the speaker specs but they dont seem to line up.
Type Full Range
Frequency Range
(-10dB) 36Hz-20kHz
Sensitivity 96dB
As a rule of thumb set the sub high pass (lo cut) to the -3db frequency point using BW18 and all other cross-over point filters should be LR24.
Jason
1. Subs
2. Tops
3. Amps
4. Purpose system is for
Model numbers and specs if possible, just like it requests in the READ ME FIRST BEFORE POSTING (or you won't get any answers) section...
There just isn't enough info to help you here...
1. Subs - None
2. Tops - Using an older model Yamaha speaker (sorry I am not sure of the model) hooked up to the High output. Also using MTXP215h hooked up to the Low output(they look like they are similar to the JBLJRX125s in the way you can use them. yes I know the MTX is not a JBL). The MTX specs are included in my previous post.
3. Amps - Crown Powerbase 3.
4. Purpose system is for - small church seats 250 at most.
In setting up the cross over it asks for the frequency. So that is where my question was coming from.
I was working fine previously with just my Yamahas and the DBX. The room had been pink noised and everything. Worked great.
We have the MTXes just sitting that we were not using and I was trying to put them in the dbx to see if it was possible to use them.
Following the doc All_Output_Full_Range I set the DBX to custom biamp, set the EQ up afterwards to the same as when I had the DBX originally setup, I set the X-over settings for the high at 50Hz, LR24, and 0db and the low 50Hz, LR24, and 0db and OUT LR24 and I could hear the Yamahas clear as day but the MTX were then very soft. On the board if I turned the MTX up at least twice what the Yamahas were but the Yamahas were still much louder. So I posted to the dbx forum and followed the suggestion on the low BW18 and then I played with the setting and my X-over is now set to
X-over setting
L -
37.5 Hz BW18 10db
OUT LR24
H-
50 Hz LR24 0db
This made the Yamahas and the MTX almost as loud as each other. That is where the 10db on the gain came in for the L on the DBX. On the board I had the Yamahas half of what the MTX were and so I set the gain on the X-over for the MTX to 10db and I thought it had totally fixed my issue.
Part way through our set the MTX speakers started to \"crackle\" so on the board they turned them down and it fixed the issue. I tried looking for the frequency response of the MTX and the only thing i find is they say they are tunable to anything you want. That is where my orginal question came in.
All of the equipment was installed a while back and all of it was installed by a \"professional\". They were not doing live music at the time. We are small and with that have a small budget so I am trying to make do with the speakers I have. The Yamahas are in the center of the church and the MTX are on the side. It sounds awesome right now but I want to make sure I have the settings where they need to be and really want to be sure I dont harm my equipment.
I would also set the MTX's to 50hz.
The yamaha's are probably more sensitive (more output with less input), but this is not a problem. Using the the mtx's to \"fill\" the front on the edges that the Yamaha's \"miss\" is fine, but to try to use all 4 cabs to \"fill the room with 2 times the sound is going to hurt more than help. I'd just use the MTX's to spritz the fringe that the Yamaha's miss. I bet that if you leave the MTX x-over at -0- it will work just fine for this purpose.
Jason
A db meter would be usefull. Also a \"book on CD\" would probable be better easier than music for this test.
Good luck.
