Hot pin 3 and hot pin 2
Hi everybody.Would appreciate any help for this issue:
The Pioneer DJM 600 Main XLR outputs has hot pin '3 ' will this cause a phase problem with the dbx 260 XLR inputs,Which I presume is hot pin '2'?
But, whether in your application it will make much differene is not likely.
Now I am wondering about your comment: '' But, whether in your application it will make much differene is not likely''
Do you mean speaker cone moving in when it should be moving out?
Please elaborate..
If you were sub mixing into a pin 2 mixer and using other input devices that were pin 3, there could be phase isuues between the input devises. I'm not sure why I think that, but seems like I heard it somewhere.
Gadget?
By the way still the 260 is a wonderous gagdet! so flexible hope to get to know it better!
