Basic set up
Should I assume if I select amps and speakers that are preloaded in the drive rack that I don't have to do a gain structure? Do I just set the amps attenuators to what the DRPA display is and the wizard program loads all the settings, ie, limiters,crossovers,peq's etc? or is that just to simple!!
First off the only way your going to get PEQ's (for the most part) is when you bi-amp the tops, and the manufacturers provide the info for this purpose. Pretty much JBL...a Harmon international company. The presets that appear other than that I believe were cooked up by the DBX people.
Also, the gain structure is important to identify the mixers clip points, both channel, and master section. (how is that done with the presets in the Driverack?)
All in all I don't trust the presets..(hell I don't trust the settings JBL provides for that matter... but I have gone on record as JBL dissenter)
Here's where I'm at...
I have:
A&H wizard III board
Jbl SR4725X 2way mains powered with Crown XTI2000 -bridged
jbl MRX528S dual 18 subs powered with Crown CE4000-stereo
My DRPA does not have the 4725X but does have the 4725A. Can I substitute? Also no XTI2000 but has CE2000 can I sub this as well. Or select \"custom\" instead?
I have downloaded the \"pink noise\" for the Gain procedure. So I guess the next step is gain structure?
1 set up a custom 2X2 in the wizard... use the presets if you want but it isn't necessary...
2 set the the HPF for the sub @ 40hz BW 18
3 set the LPF for the sub @ about 110 hz LR24 since you are under powered
4 there is no LPF on the hi's so well let them do what they can (the horns)
5 either hi out to the XTI 2000
6 lo outs to the CE 4000
go to the read me first before posting for a lot more info
PS - DBX contracted me to monitor the forum almost 3 years ago and gives me $.05 every time I correct Gadget.
Including this one, I will have made $.05. 8) Keep up the good work Gadget.
thanks Dra...
Good work Dra
(you past the test)
Mark
Reading all the posts
But
You two are far too fast for me
Must be time time zone difference
Going skiing for a week so catch you soon
Fanman20
