QSC 122i and Yorkville 700p system
Just put this system together and have not set up as yet. (Subs are being built).
This is what I'm thinking:
2X4 set up
HPF: [email protected]
LPF: 120 hz LR 24 Hz
Tops:
100- 120 hz @LR 24.
The Qsc's have a 100hz hpf switch
The Yorkville subs have a High Frequency cut off that you can set anywhere from 100hz to 150hz.
This set up is for a bluesrock band that does a wide range of music. Want a good kick drum sound and some bass guitar but not overpowering.
2X4 set up
Tops:
100- 120 hz @LR 24.
With a 3db down point of 45 and 125 hz, and being as how it's a band pass sub I'd suggest 110 hz area for the xover. What do you hope to accomplish by setting the hipass @ 30 hz? If it's 3db down @ 45 hz that xover point is useless. It would only be letting the subs do whatever they want and then the crossover point and slope are academic...
A spread of more than a few hz can cause comb filtering in the crossover region...so don't overlap, but instead a spread of a few hz can lessen the interaction.
I figure you could go as high as 120 hz with the crossover but you might find it a bit boxy sounding...
These are your thoughts?:
2X4 set up
LPF: 100 hz LR 24 Hz
Tops:
110 hz @LR 24. Maybe less?
