Jbl and Crown set up
I was wondering if you guys had in fine tuning suggestions, (delay/comp/eq adjustment/,ect.)
The wizard set up that is completed and the outside EQ is done.
1604-VLZ PRO 16 Channel Mixer Board .
2 JBL Pro MP215 Forward Speakers. 1 Crown XLS 402 Amp
2 JRX Pro 18\" Subs Cabs. . 1 Crown XLS 602 Amp.
Thanks Boog :?:
Thanks Boog :?:
Most all the tips I would suggest are in the READ ME FIRST section.
Gadget, Do you feel I am under powered all atround or just highs or lows?
Thanks,Boog
Where was the mic (assume an RTA mic) positioned in relationhip to the horn throat and 15 (should have split the difference)?
How far from the stack was the mic?
How loud were you pinking?
You could get by with the 602 on the tops (380w ea.) but you have to NEVER get into clipping, even if you need more volume.
As a minimum, buy another 402 and put the pair bridged on the subs.
Better, sell the 602 and buy a 802 and another 402 for the subs.
The cheap way out is do a really good gain structure as layed out, but turn the amps back an extra detent or two. Then know that you are limited (potentially in volume) and hold your ground.
How loud were you pinking?\"
Dra,
Yes your correct ,215 on pole over sub.
RTC mic, I had the mic split between the 215 and sub(centered). not right?
Mic was 10-12 feet.
I selected MED. on the DR Auto EQ and turned it up until zero.Amps were at 60%. Pretty loud.
Thanks for the power amp tips ,I wiil look into that. I will keep the 602 to help run monitors, I know the QSC I use is trying to bridge power to 4 JBL monitors.
Boog
$150 more than the 802 buys an XTI4000...@ NSL (northern sound and light)
Let us know how it goes.
When auto EQ'ing, why have the sub turned on at all??
I remember this piece of information in the FAQ's
Leaving the sub unplugged will help in the times when in clubs owners and guests are with in ear shot. from not complaining
So the Question is
Why have the sub turned on when auto EQ'ing
Just a stray thought
Mark
Yes, back to the subject ... anything below 170 hz should be EQ'ed by ear...
G, I'd say that you got lucky(or blessed). All I see is the Ceasars Palace jump where at the landing ol' Evel's front wheel is going crazy and him going rag doll.
thankfull...
BTW ...way to tired to think on the amp thread... how about posting it in the PSW... it will get the best attention and answers there...
Can't loose the driverack guro
Mark
I took out skippy (kangaroo) in a car once.
The dogs loved him
Back to the subject
When we auto EQ turn off the subs
The skiing trip was fantastic. But only for a week
I will redo the EQ set up as you stated. also sounds Like pulling the plug on the sub is also a good idea.
One more question for today. Speaker cable...running 50' cables 12ga or 14ga or does it mattterat that length?
Thanks and maybe you need a deer whistle on your bike...
My truck has waxed 3 deer since 2000.............
Don't laugh.. I have two on my bike, one on each side of the faring...they do NOT work...deer are too stupid..and there is a bumper crop this year and they are out in the day and all over the hwy...it SUX...should be a hell-of-a deer season this year.. hope they let everyone take 4...
