Home dbx User Forum dbx Archive Threads DriverRack PA & DriveRack PA+ PA Connectivity
Mackie/JBL/Crown setup
NiteNoiseNiteNoise Posts: 2
edited September 2008 in PA Connectivity
I have an old DriveRack PA processor with version 1.01 firmware or lower and I need tuning settings for this configuration.
2 Mackie SRM 450 Mains
2 JBL MP418S Subs with a Crown XS1200 AMP
I believe the subs are 4 ohm and the crown is 1100 watts @ 4ohms
The PA Driverack has a setting for the JBL, but not the Mackies or crown.
Any help would be great.
  • GadgetGadget Posts: 4,915
    :roll: You don't need tunings...tunings are for speakers that are bi-amped, tri, amped ..etc.. and while I suppose its merely a point of semantics, what you are technically asking for is a crossover, and pass filter setup...but you would have known that if you had read the READ ME FIRST BEFORE POSTING section...you really still need to do that though...read that is...
    Otherwise the limiting factor here is the amp for the subs, and there is reasonable power for those, so..
    Subs
    HPF 45hz BW18
    LPF 100hz LR24
    Mains
    HPF 100hz LR24
