Low power adjustments
Hello guys,
As you guys suggested I have bridged the crown 402's (one to each jbl18s). I am using the crown 602 for tops (jblpro 215's) Very noticed increase in the subs and tops.
One question as I have read a couple places , since my system is in the drpa and I let the wizard set it up does it set the gain structure for me?
Also setting the drpa amp levels to the power amps in the wizard,do I set them as shown by the wizard or do I set the drpa amp levels to the amp level of my choice? And what level should I set amp as I know full out is not the way to go.
Confused a bit but learning as I go :roll: :roll: .
Thanks for the knowledge,Boog
While the wizard will usually end up close, you should do the gain structure manually (as layed out in the RMF section) and reference (only) what the wizard says.
Thanks Boog
