DBX Driverack PA with JBL JRX125s and 118S
I'm considering getting a DBX Driverack PA, to replace my behringer CX3400 crossover. I have two JBL JRX 125s which require full range signal to be sent to them, and two JBL JRX 118s subs. Does the Driverack PA have the ability to send a full range signal to the 125s, but just lows to the 118s subs?
any help/advice would be much appreciated
You could also send a full range signal to the subs.
But in either case, why would you? Both cases will hurt the sonic purity of the sound.
I have 118s to give a bit more volume to the low frequency, so am just wondering whether the PA is the right thing to get.
so the 125s need a full range signal and the 118s need just lows
So as Dra said, DO NOT run those fullrange... depending on amp power I'd recommend no lower than 100 hz... maybe as high as 120 hz.
You will not BELIEVE the difference in the sound you will get IF you follow directions...and put that BEH crap up for sale and replace it with a driverack...I had one once and it was THE WORST xover I have ever used...even the POS DOD crossover was far superior to it and IT was crap!
Does that answer your question?
Moderator
