Failure with my PA-drive
I have a PA-drive from 02 software 1.00
The other day I had a problem:
first I could not adjust anything, then I saw there was no sound through the unit.
I turned off and then turned on, and then I just had back gronud ligt on the display, otherwise the unit was dead!
Tried several times to turn on and off and no chance!
To day I turned on the PA-drive and all is well???????
What going on, you think?
I am a audiotech so I open up the unit and i se there is a 5v and a 15v powersurply and i can simjulate the problem by dismount the plug from the 15v transpormer!
Have there been any intermitend problems with the 15v powersurply?
Looking forward to a bit off help!
Regard from a keen DBX fan Jorgen fron Denmark :P
I don't recall any issues, but that is mainly a tech service type problem...You might try a hard reset..assuming it might be a software issue. You will loose any setting so make sure you can rebuild them before you try the reset.
Good luck, keep us informed
Gary
