Settings for Yorkville E215 speakers
What settings can be used for using Yorkville E215 speakers in the Bi-amp mode to get great sound?
Moderator
FYI..our purpose here is to EDUCATE as much as empower, therefore you need to take an active part in your education..I have the Elite 2204's the precursor to those speakers you have...and I know them very well, and tuning them is no easy task...
Download the P215 processor and try to duplicate the bi-amp curves on the graph with the PEQ's. I do think that it is going to be difficult, but possible. The bi-amp crossover at the horn is 2K (according to the graph).
Give that a shot. The 2204's have a 2\" exit horn (yours 1\") and the processor curve for bi-amping is greatly different, so Gadget's data won't do you any good.
Good luck.
I wouldn't use any preset ...I would instead set up an all custom preset.
So I would:
Set up a 2X5 or 2x6 with all custom speakers and amps
Make sure to go stereo and not dual mono
Load the configuration
Dra.. at the bottom of this page http://www.yorkville.com/downloads/servman/sme215.pdf they show the crossover.. but I don't recommend going that low (1000hz)....I need the info I asked for, but:
hipass the subs BW 18@ 45 hz
Lopass @ 100 LR 24
Tops, Hipass 100hz LR 24
lopass @1700-20000 hz LR24
Hipass the horn @ whatever you set the midrange @ Note the higher the xover the greater the longevity of the horn driver diaphragm...
A few hz spread at the crossover points can help minimize interaction in the crossover regions..
We need more info here, you haven't given us the information necessary to help you. You haven't read the material provided we asked you to read and we can't simply provide the answers.. it just isn't the way we work.
