amps help!!
hi all, i'm a newbie and i'm from italy
i need help to set my new driverack 260 with my little p.a.
i use a labgruppen 2000c for the 2 top in stereo ( q10 with 2x15\" and a 2\" horn)
and 2 crest audio cc1800 for the sub ( 4 q10 sb with a 15\" each , every amps drive2 sub at 4 ohm in bridge )
now the first question:
here are the specs of my amps...
labgruppen 2000c:
INPUTS
Sensitivity, switchable for full output into 4 ohms = 0.775 or 2,2 Vrms
Gain, switchable = 38dB(0.775mV) or 29dB
Impedance = 20 kohms, balanced
Common mode rejection at 1 kHz = 50 dB
REAR PANEL
Switches:
Gain =38 dB or 29 dB
Link = Tandem mono, channel A and B
Polarity B = Polarity reverse of channel B
Clip limiter A and B= On - Off
MLS= 0, -2, -4, -5 dB
Allows amplifier gain to be switched between 29dB and its normal gain at 0.775mV input sensitivity
OUTPUT IMPEDANCE = 1 kHz 0.06 ohm
MAX OUTPUT POWER
4ohm stereo -5dB=570W -4dB=680W -2dB=1100W 0dB Full=1400W, Peakpower=1900W
CREST AUDIO CC1800 POWER SPECS:
4 Ohm Bridged = 1850 W
Max RMS Output Voltage: ....... 73 V / Channel
Frequency Response: ....... 10 Hz - 100 kHz (+ 0 dB / - 2dB @ 1 Watt)
Power Bandwidth : ....... 10 Hz – 35 kHz; +0, -3 dB at rated 4 Ohm power
Damping Factor: ....... >150:1 @ 8 ohms (20 Hz to 1000 Hz)
Gain: ....... selectable between x40 (32 dB) and x20 (26 dB)
Input Sensitivity (x40): ....... 1.32 V +/- 3% for 1kHz, 2 Ohm Rated Power
Input Impedance: ....... 15k Ohm Balanced
Class: ....... modulated rail, H
Power Supply: ....... Linear Torroidal Transfomer
1/8 Power Draw: ....... 400 Watts / 3.4A @ 8 Ohms
685 Watts / 5.71A @ 4 Ohms
1000 Watts / 8.34A @ 2 Ohms
1/3 Power Draw: ....... 1000 Watts / 8.34A @ 8 Ohms
1650 Watts / 13.75A @ 4 Ohms
2340 Watts / 19.5A @ 2 Ohms
as you can see the labgruppen report:
the crest report:
Gain: selectable between x40 (32 dB) and x20 (26 dB)
and now????
what i need to do??
please..teach me to set my new jewel!!!
i
labgruppen 2000c:
INPUTS
REAR PANEL
Switches:
MAX OUTPUT POWER
the crest report:
and now????
what i need to do??
i
Gadget, explain the science here. Are the input switches merely for quieting the system, or for some other thing?
these data have been taken by the original documents of the amplifiers.
thanks still for everything of your help.
The digital consoles +20 TO +28 DBU...
Consumer gear, -10 db...
So amps with a wide range of input sensitivity make it ideal fo almost every situation...simply match the gain of the console with that of the amp.
I have made sense of badly perhaps.
I wanted to know if in my driverack 260, I have the possibility' to put the 3 amplifiers to the same input level. if this and' possible, as must I do??
these are the values of the 2 types of amplifiers:
labgruppen: Gain, switchable = 38dB (0.775mV) or 29dB
crests: Gain: selectable between x40 (32 dBs) and x20 (26 dBs)
the levels of the 2 types of amplifiers are all different ones as you can see up.
to different values there will surely be different (apart the power) levels of exit.
the mixer that I use and' an allen&heath wizard 20s
how do I owe set to the best?
driverack you can help me in this?
still thanks !!
Use these. Although it really shouldn't matter.
Ive added a FAQ for this here:
http://www.dbxpro.com/forum/viewtopic.php?p=7043#7043
g
Nice use of color Dra...
