Weird problem
One of the clubs my band plays in has a pair of Yorkville Performance Series cabs hanging from the ceiling. They have a little junky powered board. I prefer to use my rig with my DRPA and Yamaha 7000 amp, and Mackie board. I have connected to their speakers and can't get any reaponse from them, yet I do get response from my sub off one of the amps. When I plug ther speakers back into their board they work, but sound crummy. I have changed cables from the DRPA to the amp, I have changed cables from the board to the DRPA, but still get no sound from the Yorkvilles. All the while my sub is working. I am using the same set up, other than the JBL setting in the DRPA when I use my own speakers, with mains set as custom, and sub set as custom. I have double checked the cabling from board to DRPA, to amps, to speakers. Any suggestions? BTW another club that we play regularly has a similiar set up with mounted speakers. I use my rig and connect to their speakers (Fender 12\" cabs- real low volume club) and it works great.
Speakon, banana, or 1/4\"
Signal at your amp?
what setup and outputs are you using in the DRPA Include all pertinent info, crossover point, type configuration, etc...
is the speaker plug for the house tops 1/4\" phone jack
have you verified cords from DRPA to amp
what happens if you run another speaker (yours for instance) off the same output that you send to the house speakers?
are you panning for some reason? The house mains are mono right?
the more info the better.
So for instance, if you were running fullrange on the tops and subs, and the subs and tops were wired backwards.. (in other words a 9 volt battery applied to the tip of the plug + and the sleeve of the plug to the - terminal should drive the cones OUT ...unless some JBL drivers that are reverse wound were used)....
then anything in the low- low mid would cancel...as the sub goes OUT the 15 inch in the Yorkies goes IN...guess what... WEAK sound...
Sound familiar?
I'm with G here. More info needed
What equipment are you using??
Both your gear and house system (including the \"little junky powered board\")
Please supply links to the equipment's web sites, as this helps visualise how it is wired and which outputs you are using
1 question
If you were to setup the system, as you think it should work, you don’t get a signal though, if you were then to put your speakers into the same setup do you get sound???
Fanman20
Thought if Dra could use colour than I would give it a go
I have returned your PM with my PM which is still sitting in my outbox unopened.
Must mean you are not getting notices???
Mark
Mackie CFX 12 board
DRPA
Yamaha 7000 amp
Mackie 1400i amp
2 JBL JRX15 speakers
2 custom made sub cabinets with 18\" 800 watt speakers modeled after JBL JRX118
my rig works as is and with the same set up I did not get any sound out of the yorkies with them plugged direct into my amp with their cables. When I plugged their speakers back into their Yamaha powered board (250 watts per side I think) they worked.
My setting on the DRPA is 2X3 with crossover split set at 100. I have done the manual gain setting, but I can't find a place through the wizard to set the amp sensitivity. What did I leave out?
Still not making cents ?????
Still trying to work it out.
Try some different combinations of equipment
Try eliminating possibilities one by one
Any more info will help, on matter how small
Fanman20
Oh I guess you should tell me if it sounds bad even without the subs on your rig...that means the Yorkies to your system.. no subs... you'll have to run the crossover down to 50HZ or so...check that the compressors are off.. the PEQ's are off and that the GEQ doesn't have a lot of cuts either.
