Saving the RTA
A couple of easy questions for you guys
1) when you set the RTA and then re-save the entire configuration...do you also save the RTA setting as well?
2) Does the RTA setting that you saved come back up when you re-power the system?
Thanks guys!
Thanks guys!
2 yes...
But... in order for you to save the preset and tunings, AND Auto EQ plot, you will need to press the STORE button 3 times...and answer the questions Once you have stored the setup FI the red STORE light is lit, you need to store the re-configured setup, if the red Store is not lit, you don't need to re-stroe the info...
