DRPA with 2 speakers?
SevarinSevarin Posts: 12
edited October 2008 in PA General Discussion
Hi folks,
I looked through the FAQ section but couldn't find an answer to this.
Can I put the DRPA to use with only 2 speakers?
  • DraDra Posts: 3,777
    Yes, if you just answer the questions in the wizard, you'll tell it that you are running passive without subs and it will set up a 2 x 2 (stereo in / fullrange stereo out filter). Set you Hi-Pass at the -3db point of the speaker @BW18 and you good to go.
  • GadgetGadget Posts: 4,915
    Certainly, works great, Its technically called a bandpass filter, or filter where you use the High pass filter to determine low frequency cutoff. and if you want to you can set up a low pass filter as well...
  • SevarinSevarin Posts: 12
    thank you folks. Is it correct, that I need to use the 2 \"High\" Outputs in the back for this scenario?
  • Fanman20Fanman20 Posts: 223
    Yes it is
    Fanman20
    Yes, there are other posiblities, but is a little more complicated.
    Thank you again. I will do some more read up about this unit and then go ahead and install it.
    Ok, I'm back. I tried to use the Wizard a couple of times, but all I end up with is 2x4, not 2x2.
    The settings/steps I take are as following:
    1. System Setup
    2. Input Setup: Stereo
    3. Graphic EQ Setup: Stereo Linked
    4. Main Speaker: Custom Passive
    5. Sub Speakers: None
    6: High Amplifier: QSC PLX3602
    7: Low Amplifier: QSC PLX3604
    Can someone tell me, what I'm doing wrong?
    If I understood the answers before correctly, I need to end up in 2x2 Full Range. But I end up in 2x4.
    Hm, never mind. This is really weird. I turned the unit off and back on and now it's working. I have no idea, what that was....
    Hum.
    Create a new preset and see if if does OK.
    PS - You can use a 2x4 set-up by only using the Hi ouputs. You would set the Hi side of the x-over just like the filter for the 2x2.
