Settings for EV Sx500+?
Hi folks,
has anyone settings for 2 Sx500+ Speakers and a QSC PLX2-3602 Amplifier? I run them in Stereo Mode. Passive, no subs.
For the filter settings, use the -3db point on the low end to set the HPF and use BW18.
I just check the specs on that cab. EV recommends a HPF at 45hz (-10db at 43hz, no -3 spec), so 50hz sounds good to me.
That amp is an excellent choice for those speakers. Do a gain structure to set the amp levels. You will probably come up with about 10 o'clock or 40%, but do the gain structure and set the limiter as posted.
Do that, then come back with specific questions if you have them.
