Gain structure and system balance
I have a question. Assuming that gain structure is set using divided pink noise output bands.... Do I make a x-over gain adjustment?
Top cab at rated output = 128 db (x2 cabs = 131 db) (x4 cabs = 134 db)
Sub cab at rated power = 134 db (x2 cabs = 137 db) (close coupled subs = 140 db) Is this right?
If I have a 128 db capability for tops and 134 capability for subs (6 db difference), do I reduce the x-over sub output gain -6 db?
Not sure I understand the question, but it will be interesting to see what Gadget has to say.
W
Can you every have too much sub????
What is going though the subs? Band CD Disco vocal
Where did you get these figures??
What are the top boxes and subs that can produce 140 db
Glad I am not your neigbour
Mark
The 140 db sub ... 134 db is max output out a single sub (@1m) add a sub and gain 3 db (137)(right?, from doubling). Here's where my question is fuzzy... close couple those 2 subs and gain ANOTHER 3 db (140)?
My premise question is since the subs (on paper) outrun the tops by 6 db, in order to achieve flatness in the system I should reduce the input to the sub cab by 6 db. Correct? Because as we all know in theory this is a thing as too much sub, though ususlly never achieved.
g
