setup
How do you set up 4 full range speakers and a mono sub need help with freq. etc.
Do you currently have a x-over? It will much easier to find the optimum x-over point with a single knob control style than a driverack style (multi-filter). Yes the driverack will be a great tool, but for some it CAN be a step to worse sound if misused. Your multiple manufacturer top cab system is a problem maker. A driverack has many tools to help you ATTEMPT to solve that problem and in the hands of an experienced user can come pretty close to making the best of a bad situation. A traditional x-over can do nothing but split the signal into two parts. Yes, the driverack will work for you, but I don't know if I'd recommend it. Hopefully you will read the material Gadget mentioned, then come back with some follow-up questions.
