260 setup
I am having a problem (or at least I think I am). I ran the wizard but unfortunately I had to select custom for my EV ZX4 speakers because they are not included. I am waiting for electrovoice to reply with the information I need. I have done the gain structure and made sure to input the amplifier level into the program. I have not setup the AGC or the AFS or anything else other than the initial configuration. The problem I am having is that the live sound (speech) sounds distorted. I have not setup the EQ yet since I don't have a RTA mic, and this might be the likely cause. I am using the software and saw a graphic equalizer. Currently it is all flat.
1) Is it sufficient to have a slight bell curve?
2) After EV gives me the information for my speakers, how do I enter them into my program?
Thank you.
Thank you.
You don't need crossover info if your just running tops fullrange, and all you need is a bandpass filter.. set the HPF @45hz BW 18, and leave the lopass to out..There MUST be some component thats clipping... see where it is.. the 260 is NEVER to be allowed to get even close to clipping ... input OR output...see if the ZX has clip light.. try 12 oclock (zero helpful info on the EV site..) unity.. on the ZX4 speakers... make sure the mixer isn't clipping...It could be a cable issue... eliminate one by one what might be the culprit...
More info needed if were to help further
What is the system used for? Obviously, you stated speech, but what else, rock bands, piano, organ? Does your board have a lo-cut on the input channels? Are you using it for the vocal mics? How is the mic channel EQ set? How does music (CD) sound on the system?
But since people are trying to help me and I keep confusing you, what EQ setting would you suggest for primarily live speech.
EQ - set the the Hi and Lo to -0-, the Mid is a bit tricky (more complicated) because the system EQ (room & speakers) and the mic used and the users mic technique will cause a multitude of variables here. Get the system up to volume (rung out, AFS set, etc) now with the actual mic user speaking (reading, counting, whatever) set the mid FREQ all the way to one side or the other, set the LEVEL to -6db. Now sweep the FREQ slowly to the other end. Note the place that sounded best. Now start over, but set the LEVEL to +3db (to avoid feedback) and sweep through, noting the best sounding place. Now go back and tweek the -6db or +3db LEVELS to get the better sound at the places noted. Then choose the best between those. The Hi may need tweeking as well, but only experimenting will tell. The Lo is virtually bypassed but .....
You may need to re-AFS now.
The mixer output EQ could be used as a \"tonal\" adjustment for the system, if needed, but not for minute (feedback) problems. But more likely should be kept flat, until you get a better grasp on how everything is working together.
