Quick connectivity question
I just got a Driverack PA and I'm a little confused about the stereo outs. I'm the engineer for a church and our current configuration is a single sub cabinet (2 18\" Yamaha) and 3 Worx Audio 12Ai's in a center cluster.
It's currently crossed over @ 120HZ. Would I just use one of the stereo outputs to feed my amp for the Worx cabinets?
BTW, we have a Yamaha 01V96 board and 2 Yamaha P7000 Amps.
Our current processing chain consists of an Alesis MEQ 230, Alesis 3630 compressor and Behringer crossover.
I'm hoping to eliminate all 3 of the afore mentioned components with the Drive Rack. I wanted a 260 but couldn't afford it on the budget we have.
Thanks in advance for anyones help.
Regards,
David
Regards,
David
gadget
David, how are you currently connecting from the amps?
3 channels for cluster - signal is split with y cables.
Keep in mind I only have a snake with 4 sends on it and am using 2 for and external feed.
Thanks for any input!
- David
I'd set up a 2x5 use the left channel for the sub on the left mono sub out, I'd then run the ctr cluster off the three right channels one for each speaker. This way you can power shade the room. You could set it up as a L/R C setup also using 2 of the right outputs.... and the left for the sub.
Then you set up the 3/2 right outputs as partial bandpass filters by dragging the HPF to where you want it... say 100 hz LR24...then set the sub up 45hz BW18 and use the LR24 @ 100 hz LPF.
Then you can run Aux fed subs if you wish also.
If this is case what are your recommendations for setting it up?
Thanks!
David
So let's assume that I don't remote it, what config would I need to get it to send one low and one high through the snake to the amps?
Thanks!
- David
Is there some big advantage to running my cluster speakers independently that I'm not aware of?
I've never desired to have individual control over the cabinets in the cluster. They've always been a single unit. I'm just feeing them 3 channels of power because I didn't want to run my power amp down to roughly 2 ohms.
I guess I'm looking for a 2 way setup so I can have control back at my house board.
Thanks again guys!
- David
To control all 3 cabs and sub using the 2 available lines... set up a stereo GEQ (single control for both sides) and a 2 x 3 x-over. Mono mix line from board to Left DRPA input. Use Hi (L) and mono sub (L) outputs.
PS - If you would like to bridge an amp for the subs to get more power then there is an option to allow \"power shading\" for the L/R speakers (increased power to the center if you need it) using the one remaining amp. A concept \"developed\" by a Peavey guru, or at least explained.
