260 and Zones
rschultz
Hi,
Considering the purchase of a 260 for our church. Could have up to 4 speakers in the sanctuary... this leaves 2 outputs to other areas (like lobby and nursery). Manual suggests using Zones with a zone controller. How exactly does this work? ZC1 and 2 have volume control. Would I put this controller in the nursery and use as volume control... so I'd have to run a really long cat5 cable to the nursery. This would then change the line level output before my amp (70V system).
The 260 manual is extremely vague on this type of setup... is there another place I could look for detailed explanation of zone setup?
thanks.
Ryan
thanks.
Ryan
http://www.dbxpro.com/techsupport.php
and perused the training modules there?
The ZC series won't work inline with a 70 Volt system. This is how the ZC's work:
1) The ZC plugs straight into the head device (in this case a DriveRack 260).
2) The head device sends 5 Volts to all connected ZCs.
3) The ZCs then apply an amount of resistance-dependent upon the setting-and send this Voltage back to the head device through one of the remaining wires in the Cat5 cable.
4) The head device interprests this Voltage value and makes the changes in it's DSP.
Note: Make sure that there are no lines (such as AC or 70 Volt feeds) that run in parallel with the Cat5 cable as this can cause interference (i.e. random functionality or non-functioning ZCs).
