DYNACORD F8 & F150
I am putting together a system with driverack PA with the following:
2x Dynacord F150 400W RMS 8 OHMS
powered by
MA-2402 stereo 505w at 8ohm per chan.
and
4x Dynacord F8 bins 500w RMS 8 ohms
powered by
MA-3600VZ 1565W at 4 ohm per chan
I plan to put 2 bins to each channel on 3600vz unbridged .
Any suggestions on crossover/eq/speaker tunings etc?
The dynacord speakers above come with a pm2600 system amp and i was going to copy the crossover settings from this:
110hz crossover frequency , 12db/octave
powered by
and
powered by
Read the FAQ section though, it has LOTS of good info on the Driverack setup procedure...
can you explain what BW18 @ 45hz setting is? i understand all the rest.
and be damaged. With that much power that is very possible...
Thanks for your help.
Also room modes set up in live sound @ 250 and 500 hz areas...
