Newbie with Q on how to connect to my new DBX 223xl.
I've been reading lots of posts and couldn't find an answer on how to connect my specific set up to the crossover. [DBX 223xl] Anyways I have a soundcraft gigrac 1000st mixer with the internal 2x 500watt amps powering two Peavey 115s, and a crown powerbase 2 pushing a single Tapco 6918s subwoofer. I'm a drummer/lead vocalist in a three piece rock band and we just bought the sub and x over to hopefully run all instruments through our PA for better sound. Also this subwoofer has a lowpass filter built in will this interfere with the x over. Any help would be greatly appreciated. If you need any more info in order to help let me know. Also any suggestions on settings would be helpfull. :oops: :?
Perhaps you could contact Soundcraft and see if there's a location to interrupt the signal path to the power amp section...
cables from mixer to 223 and you could use 1/4 \" cables from the 223 to the gigrack. Balanced (TRS) would be best but unbalanced would probably work.
If you look at the back of the 223 you will see on the to line back of the unit channel one has an input and a High and lo out... on channel two you have the same.. this is for a two way system in stereo.. or mono if you SUM the lows.. this is what you will be doing...
The bottom line is for a MONO three way system...Input signal on channel one...Lows come out of channel one (the high outs are not used).. mid and highs come out of channel 2 (the ch 2 input is not used) just like it says there...
So you would come out of the Yamaha mixer into the channel 1 & 2 inputs of the 223. the high outs would then go out of the 223 to the Gig rack. Pick 2 channels and zero the EQ and set the input gain at unity.
Not sure what input the powerbase has but I think they had 1/4 \" ins and no XLR's? but you want to sum the outputs from the 223 and use the channel 1 output to the BRIDGED mono Crown amp.. the two RED posts will feed the sub.. pay attention to which RED post has the + sign and make that the subs +.
Set the Xover @ about 100 hz (tough to tell with that thing... and then use the channel 1 volume control on the Crown (turn the Channel 2 control OFF) to ballance the sound from the tops to the bottoms...
You'll have to play with the levels to get a proper setup, but start with a proper gain structure on the Yamaha, and than do the same for the ggirack.. you'll take the speaker outs of the gigrack to the yamaha's and have the GEQ's for use in the system, but no EQ for the subs...
Luck..
Good luck..
Dude, you REALLY want to take your sound to the next level.. get a DRIVERACK!.. this is esentially a Driverack forum, I'm just an OLD SOUND MAN.. that's older than dirt and seen it all, and who keeps up on the latest gear and I know how to implement most of it because ... here it comes.. \"I OWN it!\"
Any way... try a Driverack some time you won't believe the difference!
G man
