drive rack right channel,,,cuts out then gets loud
ermac4482ermac4482 Posts: 6
edited January 2009 in PA General Discussion
OK I HOPE IM IN THE RIGHT AREA... SO MY DRIVE RACK PA RIGHT CHANNEL WASNT READING AS HIGH ON THE L.E.D.'S . THE RIGHT CHANNEL WASNT BUMPING AS HIGH AS I SHOULD BE. THE LEFT SIDE WAS LOUDER. THEN THE RIGHT CHANNEL SOMETIMES QUIT WORKING . NOW WHAT HAPPENS ,IT WILL WORK NORMAL SOMETIMES FOR 5 OR 10 MINS THEN JUST GET ALL LOUD OUT OF NO WHERE.(VOLUME JUMPS UP) HERES THE SETUP
P.S .... I TRIED CHANGIN CORDS AROUND , DO YOU HAVE TO CHANGE THE DRIVE RACK TO FACTORY RESET?
1CROWN XTI 2000 TOP CAB 15 INCH MRX JBL (MONITORS) XRL INPUT
1 CROWN XTI 4000 SUBS 18INCH JBL MRX XRL INPUT
MONSTER POWER CENTER 3500
HEATH & ALLEN DJ MIXER XONE 42
  • GadgetGadget Posts: 4,915
    You do realize that all caps is considered YELLING :shock: don't you? There's a good chance that you will need to try a factory reset to solve your problem. This will erase your program so make sure you can rebuild it once you do.. if that doesn't the problem you will need to contact tech support...above
  • DraDra Posts: 3,777
    Is it possible that the compressor is engaged on the right channel?
