Driverack PA Gain set up - Disabling limiter on amp?
Hello all, I hope all is well. I want to set up the gain structure for my system. The instructions say that I have to disable the power amp's limiter. I have an EV CP2200 power amp. I have looked through the manual and it shows no way of manually disabling the limiters. What can I do? Thanks
Martin
Martin
I think I'd use the limit lights as clipping indicators. Then possibly put the DRPA just in front or behind that point, depending on if you want more or less.
But what would be the purpose of rating an amp @ 2200 watts @ 2 ohms if you can never achieve it? Another EV brainstorm...
G :idea:
Why do you think I chose THAT avatar? I seem to beat my head against the wall and it never seems to change...
That said, this thread has been about a specific amp and it's gain structure setup... now however, it has taken on a \"whole system\" complexity, and even though it seems we need more info I have to say, it still falls into the same category as all the others...Do we just use the \"amp sensitivity method\" or do we mess with the crossover gains to bring the \"amp sensitivity\" voltage into play... your choice, but in the end it really isn't going to matter unless you exceed the headroom of the DRPA... and if you do... there will be HELL to pay...Just ask Dra what happens when you exceed the amps capability...
WARNING.... IF you start messing with the xover gains in the driverack.. make double dog sure you NEVER, EVER, come ANYWHERE NEAR clipping...12 DB of headroom is NOT too much...if you do clip the digital signal...\"Well, pilgram.. that's inviting a passel of trouble\"
IF you can't balance the mains and the subs with the sub amp cranked.. then adding xover gain is a necessity.... adding too much gain can cause digital clipping, and that AIN'T pretty! In fact it is downright DANGEROUS...Want to blow drivers... digital clipping will do it with very little over the clip level... analog distortion is a TOTALLY different subject..It is considered \"warm\" and desirable... Digital clipping is BAD... REALLY BAD... like SERIOUSLY BAD...get it?
I did read the RBP, FAQ and elswhere, but I didn't see an answer to my initial problem anywhere so I posted. I did not forsee the turn of events, and now it has become the initial problem plus. When I turn the low gain up on the Driverack PA, I will certainly watch for and keep adequate headroom.
Still, don't know if I should raise the gain for the subs before, or after I do a gain structure setup for my system....( tend to think it's after)
Anyway, My setup is as follows:
Tops - Pair of EV ZX4s (400w rms, 8 ohms each)
Amp for tops - QSC PLX1804 (600w/8 ohm, 800w/4 ohm per ch)
Subs - Pair of JBl MRX518s subs (4 ohms each, 500w rms each)
Planning to get an additional pair of MRX518's soon.
Amp for subs - EV CP2200 (500w/8 ohm, 800w/4 ohm, 1100w/2 P/Ch
I guess it boils down to a compatibility issue....I cannot optimize my set up with the EV power amp. What a shame, or a sham.
I will experiment prudently.
If you see anything else with the equipment now listed, let me know.
Once again, thanks for you time and help fellas.
Zonked
If you do not do the gain adjustment on the DRPA BEFORE you do the gain structure, you will negate the whole process...
Besides, you haven't even tried it yet to find out if there even IS a problem...
