DriveRackPA===>>GUI
assistance needed. i found out over the weekend that using the gui will allow me to set up/make changes easier. reading some of the posts, i have some concerns.
does the gui work with driverackPA? if so, which one do i download?
i use a mackbookpro. is the software compatible? if it works with mac, what cables do i need to interface?
super thanks...
djsd
super thanks...
djsd
DRPA does not have a port, so can't use Driveware.
However, if you can run windows applications, then it is a good learning tool to download the Driveware for the 260 and play around with it. It will really help you \"see\" what is going on in the DRPA. (might even make you buy a 260, 10 times the machine for less than double the price ($700).
