DRPA/Crown/JBL setup
cam
Newbie here: I have a Yami 01V96 board to the DRPA, 3 Crown XTi 4000's, 2 JBL SRX 718's and 2 MRX515's. I want to run 2 Crown XTi 4000's ( one for each sub ) and 1 XTi 4000 in Stereo to the 515 tops. I have a 4 wire speaker cable, one to each Sub then patch from each Sub to the Tops
Do I need to config the 2 4000's as Bridged MONO and how do I set it up in the DRPA??? I can't find that type of config in the DRPA....
Thanks in advance for you input!
Cam
Cam
A 2X3 cofig should suffice, you have power enough for only a xover in the 110-120hz range (625 watts to the tops.. little headroom, so a higher xover point is warranted...
Use like xover types for the sub to tops, I like LR24, use a steep falloff for the sub HPF I like BW18...
gadget
I've already been using the cables from 1 4000 bridged at 4OHM for the 2 718's... adding the 3rd 4000 as I'm very short on Sub power with 1 4000.
That's my curent xover types now..LR24 etc
Thanks gadget!!!!
Dennis
Dennis gave good explanation of the power issue..
In general, overlapping the low crossover point will create a coupling zone and when time alignment is done at that crossover point, coupling will occur. End result is more low end response.
Almost everything we do in live sound is a compromise and to address that, I am going to quote a couple lines from Bob McCarthy's \"Sound Systems: Design and Optimization\": \"Since the wavelengths at the high end are the smallest, they will have the least margin for phase offset. Therefore, controlling the high-frequency overlap will be crucial. Mid-range and low-frequency overlap can be accommodated to a larger extent since the wavelengths are long enough to minimize cancellation.\"
Dennis
I've seen it done, and never really saw the benefit in it. I think perhaps when Bob says: What he is indicating is that \"it can be accommodated\" but it doesn't necessarily have to be a good idea...The overlap of frequencies in the crossover region has been shown to create irregularities in that region. A PEQ can help if you have some deficiencies in that area ... say from spreading the crossover point a little... A perfect example was a band I saw tonight...Behringer powered tops and two different powered subs...no crossover... as I walked the room I found a power alley, and about 7 very distinct fingers in the low to lo mid frequencies...of course the subs were improperly placed, but one would have been ok in the right place...but the sonic hash had the bass and kick nearly indistinguishable. There were multiple problems here, but the point I'm trying to make is that we go to great lengths to try and minimize the interaction with:
The walls and floors(ceilings too but from coverage patterns a lesser problem).
Each other.
The boundary's especially with concern to the 80hz frequency.
I've read pros and cons for additive overlap and I have to say the preponderance of information is that it is more destructive than useful.
And that is my opinion...
An opinion we might share regarding mid/high cabinets is once we find correct EQ, crossover, and time settings, we \"set it and forget it\".
An opinion we might not share regarding subs is that they should be re-time aligned in each venue to compensate for the room's characteristics. Without even seeing the band last night I am going to stick my neck out and and say I think their problems could have been corrected with a DR260 and SMAART. Repositioning the subs would be a second option. Quite often in a venue, there are not a lot of options for speaker placement.
You said \"What he is indicating is that \"it can be accommodated\" but it doesn't necessarily have to be a good idea...The overlap of frequencies in the crossover region has been shown to create irregularities in that region. A PEQ can help if you have some deficiencies in that area\". If the overlap isn't going to work and you have combing issues, they are probably in the time domain which can't be corrected with a PEQ.
I recently did an installation in a club that was 40' x 80'. The system had only one sub. It was a dual 18\". It had plenty of power but I had a terrible time covering more than half of the room with low end. I finally overlapped the crossover point and the system woke up and gave me even coverage through the whole room. Will this work in every situation? No, of course not. It is just another tool in the tool box.
Dennis
What I was speaking of with regard to the subs.. I wasn't saying TIME aligning to the room ...I never do that, I do align the mains to the backline...I do align the speakers..and mains within their relationship to the subs. In complex situations I have even employed delay to increase intelligibility of spoken word within a space with a 1.5-2.5 ms reverb time...But what I was speaking of was (boundary cancellation) the location of one sub about 3.5 feet from the boundary... that is a classic no no for live music with Kick drum as that is the cancellation length for the first harmonic of the kick drum...(here is the link to just one of the things provided in the FAQ section to help those that want to know)
http://www.peavey.com/support/technotes ... lation.cfm
The rule of thumb for subs is more than 8 feet or against the boundary(wall)...
Thanks Dennis for your contributions here. I was in no way discounting your opinions, just offering mine as perhaps a counterpoint...All sound is subjective and what is one mans nirvana is anothers sonic chaos...Stick around, it's good to have you here!
Dennis
So let me ask this, I see now I am underpowering the 515 tops... is it possible to run one 4000 bridged 4 OHMS, to the tops, then the other 2 4000's, each bridged at 8 OHMS to each sub.... and still run 1 4wire cable per side?
I know the tops would be overpowered so to speak but wouldn't I acheive more headroom that way as opposed to running the 4000 in Stereo and underpowering them??
How would I connect from the DRPA to the amps, then to the panel, then to the subs, with my 4 wire cable... can I please trouble you to explain in as much detail as you care to share... :? ???
Edit 1... Is this correct?... L/R out of the LOW on the DRPA to IN of Chan 1 and 2 of 4000(A)m then LINK to IN of Chan 1 and 2 of 4000(B)......
OR
L of DRPA to Chan 1 of 4000(A) and R of DRPA to Chan 1 of 4000(B)????
Gracias!
This again would require a special cable that is marked for the tops.. from the subs, and HAS to be hooked up only one way... OR you could rewire the second (thru) connector on the subs...if you re-wire the sub, you would wire 2+ 2- from the input(from the amps) to the 1+1- of the thru jack in the subs... this would then HAVE to be marked on the jacks on the subs, and used that way...
Yes it would be better to have the power...that is 1600 watts per speaker available...
Form the JBL website:
[/quote]
MRX515 Power Capacity 400/800/1600 watts
No need brother... no need, just keep up the good work!
The top amp ... in the picture should have the wire going from the channel 2 red+ terminal to the panel 1- terminal.. all else is the same...
Geez I jave tried and tried to get the new photo to load... but it won't...
It's been a LONG day...
Dennis
