Beginners Auto EQ Questions
First off I want to preface this question by saying that I have searched and I have read the FAQs, and unfortunately I'm still confused about some things with the Auto EQ function of the DriveRack PA. We are using the PA at my church which meets in a school cafeteria each week. I went out and bought a dbx RTA mic because I thought using the auto EQ function of the DriveRack would allow us to zero out the main EQ on our Mackie mixer. I'm beginning to wonder whether or not this is actually the case.
I used to have a car stereo that had an Auto EQ function, and I made the mistake of thinking this would be as simple as that. When I went to use it yesterday I realized I had no idea what I was doing. I tried reading the manual as well as the FAQs here on the forum, but I'm still not sure how exactly to make this work.
My first question is whether or not I actually can use the Auto EQ to replace the EQ on the mixer. If I can, then what options should I be choosing between the Flat (0), and Response A-D, and Low, Medium and High Precision?
My second question is, how do I know what pink level to set the room at? It says to use the same level that I'll be using during the performance, but how do I know what level I'll be using during the performance?
And finally... When I did try and make it work yesterday, the Auto EQ never actually finished. I made some guesses on the settings and it started doing its thing, and I saw the progress bar move, but it never completed. When I would rotate between the two available screens I would see the progress bar go backwards. Eventually I had to manually stop the process. Is there supposed to be some sort of \"completed\" notification, or once it stops making changes does that mean it's done?
I apologize if any of these questions are stupid, I really am trying to understand. I've been thrown into the role of sound tech because I know the most out of anyone else in the church. Unfortunately that isn't saying much at all, and I have no idea how any of this is supposed to work.
What is you goal? no feedback? Describe the room (size, wall and ceiling make-up, etc) Is there a recessed stage like many schools have? Are you using it?
Get back with these (and more) and we'll proceed.
Ok, you never did say WHAT mackie mixer.. and which EQ are you speaking of? If it's the channel eq's ...absolutely Not.. If the mixer has a GEQ it is limited to a few bands and is pretty useless, so yes the 28 band EQ or the 9 band PEQ will be WAY better...
Well, the thing is the DRPA won't let you exceed the level that would peak the unit...in the rock and roll world we consider the process very painful... since it's usually as loud as the unit will let you go...for church purposes try going up to where it promps you to \"turn down\" the pink noise, and lower it 3-5 db and try that...(with some thoughts first though)
From the FAQ section here:
http://www.dbxpro.com/Forum/viewtopic.php?t=949
I go on to explain about mic position, room features, and all the nasty little things that can happen with the Auto EQ... So, after discussing the traps and pitfalls of the Auto EQ process this...is added:
Now we know that we should flatten the speaker as best we can, establish a preset and store this flat preset so we have a baseline...
And with this info what to do to perhaps sweeten the sound a little.. to taste...
This is what we can do with the stored flat preset.. and here:
http://www.dbxpro.com/Forum/viewtopic.php?t=953
is the BEST way to get a flat sound for your system...
Here is a further clarification of the process:
http://www.dbxpro.com/Forum/viewtopic.php?t=1617
Now, I would read the \"getting started\" post:
http://www.dbxpro.com/Forum/viewtopic.php?t=960
and I hope you started here:
http://www.dbxpro.com/Forum/viewtopic.php?t=959
So, with all this effort concentrated on the Auto EQ process I can't see how you didn't see any of this.. had you read THESE FAQ's?
BTW in there it clearly states that if \"More than 4 bands are fully CUT or BOOSTED\" the \"NOT Finished\" will be displayed.. if you have chosen to use DUAL mono, it will also display \"Not Finished\" ...It also tells you why.. the bands are cut or boosted...
More questions?
Gadget chief DRUG guy...(drive rack user group)
As for your question about our soundboard, it's a Mackie CFX.MKII 16 channel mixer. We use the channel EQ's to tweak the individual channels, however the main EQ (9-band) for the board is also being used as well. I have no idea who set it where it's currently at, it was done way before I started running things and I just haven't attempted to make any changes since as I mentioned I'm still trying to learn as I go here. My hopes were that I could use the Auto EQ function of the driverack and zero out the main EQ on the board.
I don't have the exact dimensions of the room, and unfortunately any guess I make I'm sure would be way off. What I can say is we set up seating for about 130 people each week, and that gives us about 15-20 feet on all four sides of the chairs. The front and back walls are concrete, and the two sides are lockers. The front of the room (behind the stage from the left side wall to the right) we hang pipe and drape in order to hide as much as possible the fact that we're in a school cafeteria.
Our goal is to basically have our sound setup be as good as possible. There really wasn't anything "wrong" with how it sounded before, we just think it could probably sound better since we haven't done anything with the EQ on the DRPA.
Dennis
Ok so no horns...and no highs, no lows Bose...Why not try the \"new indoor method\" and see if you can't get a flat preset? After a pass even (when) it fails (with the bose you may not get away with a full pass .. it may not finish) press the 'preset' button then the \"EQ\" button and if it's not on the GEQ toggle to it.. see what the Auto EQ has done to the GEQ.. tell us what that is...
Did you say the side walls are curtained?
I think if you do the Indoor method.. and try that and get back to us...I think you'd be far ahead to try and keep the sound on the audience and off the walls and ceiling... which will prove difficult with the bose...
My comment here might have been covered in one of the links above. If so, you will read it twice. If the auto EQ has fully cut or boosted a frequency, I would be suspicious the issue is caused, directly or indirectly, by a cancellation due to combing. This can't be corrected by EQ. It's a timing issue that you probably aren't yet ready to tackle. Try moving the mic a couple of feet, hopefully out of the cancellation(s) and try the auto EQ again.
Dennis
1. You tuned your system and saved the PEQ settings to where it made your GEQ show Flat.
2. Save the crap out of those settings -- this is your \"New BASE Default\" for your system. Don't let anyone mess with these. Save them everywhere in your DriveRack -- User patches)
3. Go into a venue and run the RTA -- save the settings from 170hz-700hz. Ignore the rest and use your ear to tweak those upper and lower frequencies. Make boost's where you see fit. ex. 80hz for kick..
4. SAVE those settings and Name it for that venue. You now have your system dialed in and ready for the next time you are there. ENJOY!
5. Next venue -- pull up another Flat Response patch from your saved settings (New BASE Default), RTA again if you can and do the procedure all over again...... Hope this helps and if anyone wants to add to this go for it and if I am way off -- someone please step in. Thanks!
Just a couple minor caveat/points...in the \"How it's supposed to work\" the key here was a room that was awesome to begin with, with only a few minor issues... probably the best room for music in a long long ways... The stage had rounded corners, was completely carpeted floor to ceiling, and the LABsubs were corner loaded... The tops were mirror image 40X60 pattern with seamless integration, and they crossed about 3 feet in front of the stage.. which offered plenty of buffer to the stage, but had lovely coverage. A room that I will perhaps never equal...I miss it badly...
So you might not get the same results(Your mileage may vary...)...ANY and ALL maxed out bands ARE SUSPECT!
YES with the PA.. store often and multiples are good.. but a hard copy of the settings is a MUST.. if you want to have a backup with the PA.. on the 200 series and up, an upload to the computer of the .dwp file will ensure a backup...
As for minor adjustments AFTER the gain structure.. mostly no.. I don't re-do BUT if something is considered \"suspect\" like a broad PEQ with a 2 or over gain... well...you have to make a judgment call if it's enough to cause the amp settings to become suspect...
Mark, I really don't find that I need to change the sound of the flat response for the most part. As I said I understand room acoustics and reflections, and standing waves and can make a judgment assumptions from the differences between the flat preset and any changes in the Auto EQ for the same room... that is NOT an easy task...and you should only attempt this if you think you to can make the calls... Minor seasoning shouldn't make a big change except in reverberant spaces.
Thanks J, I do work diligently to make sure that accurate advice and techniques are available, and without TOO much TECH overload...There IS a steep learning curve, and with the technology, a certain obligation follows... you need to understand the technology, and impliment it correctly. If you do, you get good sound, Its no accident.
Be well all...
Gadget says:
Also about tweaking AFTER you set the system up flat:
One other thing Mark -- Keep in mind what Gadget said earlier after my initial take on the RTA thing. Gadget -- listed several things that made the room he was in a good candidate to even RTA in the first place. Here they are:
Anyway I know you want your system to be the best it can possibly be as all of us do but it may or may not be worth the hassle to go through the RTA in buildings that are horrible to begin with. We play a couple places where it is nothing but concrete on all of the walls & floor plus the ceiling is some kind of corrugated metal. Not a good room. I never bothered to RTA this place. Maybe I will sometime and just do a comparison but I am not sure much will change. Just do what Gadget says in one of his other threads: Keep the sound off the walls and on the people. Who cares about the guy in the back corner on the Poker machine.......ha. What we do when we go in places like I have described is put all cases (Drums, guitar, bass, cord cases....etc. and pile it up on the back wall and place a backdrop or some kind of curtain to try and reduce the reflections on that back wall. Particularly with our drummers SNARE drum. Another thing you could do that we all want anyway is to get everyone you know to come to your shows. The more people -- less reflections. Oh you also mentioned something about using compression on the house. Hmmm -- I better go over to that thread and help you there.
