DRPA Set up for MRX525 and MRX518S
MAXMAX Posts: 3
edited February 2009 in PA General Discussion
First off, I have read The FAQ and Start here. Just got my DRPA yesterday. Here is what I am trying to do.
2 MRX525
2 MRX518S
4 QSC RMX2450
I want to be able to run each cab and subs into each of the QSC's in a bridged mono config, but maintain a stereo set up off the board. I am guessing a 2X4 set up is what I need. Do I run it from the wizard or should I do a custom. Also, does the gain structure set up vary at all with bridged mono on all amps. Thanks
  • DraDra Posts: 3,777
    The wizard really gives you no advantage. Go all custom. Mono vs stereo (amps) changes nothing in the structure.
  • MAXMAX Posts: 3
    When I went back to do all custom, it gave me no option for the high amps to be bridged mono. On the other hand it did for the lows. Is this correct?
    Not offering bridged amps on all outputs must have been an oversight by an engineer. That's just another reason to go all custom and do a gain structure and system balance manually.
