AFS in Live mode
Hi folks: I have a question regarding the use of the AFS. I have gone thu the steps of setting up the gain structure and completeing the out door Auto EQ / PEQ flattening for the speakers. I set up my PA for 2 gigs this past week and had a problem using the AFS. Perhaps I don't fully understand it's use.
I set the unit with 6 filters in Fixed mode and 6 in Live mode. I raised the mains up until the system fed back and the AFS captured and notched the 6 feedback points perfectly. However, when I swithced the unit to Live mode...the AFS would only activate when a screaming rip of feedback tore off our heads and it did not activate or capture every time. You could hear feedback points beginning to build during the event but the AFS would not capture them. I tried Music low thru High, Speech...everything.
I should add we had a mixture of Live Music and Speech (with a Feedback prone lavallier mic, and I swithced the AFS Live mode to the appropriate setting)
My question is this...Have I misunderstood how the AFS Live mode works? Does it not detect a feedback point in the midst of Music and filter it out leaving the music intact? If you have to wait until a burst of feedback detroys your hearing it seems to me that the unit isn't functioning or set up correctly. Have I misunderstood the AFS Live function? Other than that I'm thrilled with the unit.
The problem is an OMNI mic, behind and below the voice of the user...with a small element...and crappy frequency response to boot...
Seriously, over the ear and taped to the temple is fair. If they wear a hat, taped to the brim. Glasses, taped to the frame.
Jack Bauer's in ear mic might work nice, but he might have to kill you.
PS - I heard that Minnie Pearl's dangling price tag was actually a lavalier. 8)
Are you using the GUI? Do you have 12 total filters selected? And 6 fixed? As a test, select 12 total and zero fixed. Are they being caught same as before? If you have the fixed tab selected the \"Lives\" will never kick in because you are telling it to work on the fixed.
I'll try running the board hotter at my next soundcheck next week and let yu know if there's a difference. Thanks all....
