more gain questions!!!!
Dudes.....u ahve helped me out tremendously in the past so I'mm goona ask for help again!!!
Now that I have a very basic understanding of how DRPA works I'm really confused about something so here goes....
I've done the gain structure as posted and everything seems fine...no clipping. But my amp gain knobs are not even halfway -up...seems to me that you arent using all the power the system has???? I have a QSC2450 that I am running for the mains, the EP2500 behringer for the subs...all my amps are bridged. Does the db setting in the crossover/limiter have something to do with this and if it does how should that be set......it has such a wide parameter range that im not real sure what it does......anyway i hope ya'll can help with this..
David
David
What would you suggest for a system that I just wanna be able to set up easily with only a few minor adjiustments for mostly small clubs....
Im running behringer subs
Peavey sm2 tops
mackie cmx board
david
If you apply enough signal to a amp 90% down it will clip (go beyond max rated power). It will take relatively little signal to clip an amp 5% down (but not neccessarily of coarse
So in the end, amps CAN achieve full power (in theory) at any setting.
PS - Gotta be SP2's
Here is what I think :idea: .
The econony over the last year or so had a cold.
The national media (elite) hated a certain Pres. so bad that they tried to convince everyone that the economy had the flu.
The wrong medicines were shoved down our throats and now we have pneumonia.
Of coarse, everyone knows the cure for Pneumonia is breast augmentation. :roll:
Money rules...NOT the people...
G :evil:
Oversite - In an effort to watch over, missing the scene (point) entirely.
example:
You can't have plastic on your windows to keep out cold air, because plastic is made from devil juice and landfills are ugly.
And that keeps me warm how?
Well, you need to put in some Earth-saving energy efficient windows. They'll keep you nice and warm.
I have PLASTIC... STAPLED... to my WINDOWS, and you want me to buy the Cadilac of windows?! Do those come in 24c gold? I might as well get the gold ones so the bank will have something nice.
I could go all day.
Sorry guys.....heres what I have...my tryping skills suck!!
peavey SP-2's (2)--run bridged with qsc2450
behringer subs b1800's(2)--run bridged with ep 2500
mackie board into drpa
some general setting would help the bass player/sound guy (me) get a decent clear sound with thump and plenty of headroom and clarity....alsi I have heard about tri-amping those sp2's....i have another ep 2500 just sitting there...is this an easy task or forget about it for a novice like me??
dave
www.myspace.com/trepidband
100hz is typically a good staring spot using LR24 filters. Add a BW18 or even 24 on the sub at -3db point (which I didn't look up) or 40hz, whichever is HIGHER.
any other suggestions???
david
thanks dudes
Because there you will find ...this:
http://www.dbxpro.com/forum/viewtopic.php?t=1080
and this...
http://www.dbxpro.com/forum/viewtopic.php?t=1081
and this:
http://www.dbxpro.com/forum/viewtopic.php?t=1204
and this:
http://www.dbxpro.com/forum/viewtopic.php?t=960
Read those and if you have questions I'll be glad to answer
