Polarity -- Gotta check it!
G - I just picked up a new toy called a Galaxy Cricket by Galaxy Audio. It has a polarity checker on it as well as various cord checking functions. I started going through my ENTIRE system starting with all the cords. I actually got through all of the cords and only TWO were wired wrong where somebody (most likely me) attempted to fix them. The #2 & #3 pins were reversed. Ok -- no problem I will just reverse those two. When I got to the power cords that have Neutrik connectors on them I just eye-balled them making sure they were a +1 & -1, +2 -2.....etc. When I got to my speakers I found that one horn on my monitors was reversed & BOTH horns on my Mains were reversed! I couldn't believe it. All this time I have been using this system and the friggin horns were reversed. I knew something was wrong with the monitors because they had this wierd \"outer space\" like sound to them. I just flipped the wires and the polarity checked out ok even though they come from the factory wired wrong. You were right -- you can't believe what the manufacturer states is right. We are Talking 3 out of 4 horns! The Cricket confirmed on my mid woofers and the subs what I already knew by using the 9 volt method. I even checked out my guitar cabs for correct polarity as well. What a cool device this thing is. My 24 channel snake was all good as well. So now I have a couple of questions. On my mixer (SR24-VLZ Mackie --- I know I know you love those things don't ya?
) The inputs and outputs showed Balanced and in polarity BUT my Aux's all checked out UNBALANCED in polarity. It states right on the mixer over the top of the Aux's -- Balanced / Unbalanced. So is it common for the Aux's to be actually UN-balanced but you can use a Balanced cable on them or is something not right with this board? All 6 Aux's are like this. The same scenario goes for my Power amps. I use XLR's on everything I can just because they lock in place better than a regular cord. I don't know how to really check the power amps because the outputs or the speaker cables coming out of the amps to the speakers are all TWO wire Speakons --- so they can't be balanced. I guess here I should just make sure the polarity is correct by hooking the whole system up. And my final evaluation was the DriveRack itself. I couldn't get any definitive answers checking that thing. The cricket kept giving me Red flashing lights when the switch was in the T-2 position AND the T-3 Position. If pin 2 is \"hot\" I would have gotten a green light in the T-2 position. If pin 3 was cold then I would have gotten a red light in the T-3 position. I am only getting Red lights. Any advice on this? One last thing -- I haven't hooked the whole system up yet so I know that I still have to check to see if the polarity is consistent through the ENTIRE PA from the microphone to the positive outward motion on the speaker.
Dennis
On page 28 of the manual the block diagram shows a quasi~balanced config, I assume will allow the use of either a balanced or unbalanced config...the diagram shows a resistor isolated ground in this case.. so ya it's particular to this mixer... and typical of the Mackie CRAP
As for your \"highly modified\" speakers...
\"I just flipped the wires and the polarity checked out ok even though they come from the factory wired wrong. \"...well...I wish you'd straiten this out
The Driverack does A/D conversion and once onside the unit it's all digital so I'm not surprised that you cant polarity check that...
Dennis
What speakers are they anyway...went to look but... too busy..
I would say that unless they are JBL... then yes believe the pulser...JBL reverse wires some drivers...go figure...As Dennis points out some crossovers DO skew the phase so far that reverse wiring the driver is incorporated... but those are very complex ones and seldom if ever used in livesound speakers...
Take a look at the schematic and see if the negative and ground are separate feeds from the op amp... or just a resistor between the two... I'll look later.. Right now I'm super busy bringing my \"genius\"
Sorry.. meant to address that but again... genius...
Gotta fly..
be well!
Believe your Cricket. It is working perfectly fine. If you get inconsistant readings on subs, temporarily increase your low crossover point to 200 or 300Hz, do the test and then restore the correct XO point. For more complex tests, this could create a problem but for Cricket tests it will work fine.
Dennis
Definately do some tests to see how things sound. Monitors on the other hand CAN benefit being out of phase to reduce feedback (in the right setting). Many monitor boards have phase inverters on every channel.
http://mixguides.com/studiodesign/basics/understanding-phase-sound-1001/
Dennis
Don't beat yourself up about it... next we need to start looking at issues like Impulse response, Transfer function, and THEN we can start to deal with Phase response...and Polar response...
Remember...it's all about the learning curve...and this ones a STEEP mother...
have fun... I'll send you a program...
Dennis
http://srforums.prosoundweb.com/index.php/m/271190/0/?srch=phase+shift#msg_271190
Dennis
Dennis
Dennis
