New 266Xl user/MPC-korg connection question
Hello to all....pardon my ignorance pertaining to such simple matters but Im rather wet behind the ears when it comes to rack mount units.
Ever since i started making music ive always relied upon the internal effects that were provided to me from the machines that ive been using.
Im currently Using an MPC-2000xl midi'ed up to a korg ESX-1 and a microkorg. Whenever i needed compression i would simply just run my raw sounds through the audio inputs of my other electribe the ES-1 or run everything through the inputs of a Boss br-532.
.....After hearing so many good things about the DBX brand and the 266XL in general, i finally decided to drop some cash on one.
So here i am!
The employee that i bought the dbx from at guitar center reccomended that I use \"ring tip\" 1/4\" jacks to connect my MPC directly into the input of the DBX. Is this type of cable suitable for the job?????
It looks as if i could also connect the 1/4\" stereo jacks running from the ouputs of my MPC into a 1/4\" jack y-cable and than run those into the input of the DBX? is that type of connection suitable as well???
Thanks...any help is appreciated
So here i am!
Dennis
Thanks for asking though.
you need a mixer.. send the signals of the 2 keyboards into the mixer, make adjustments there, then if you MUST process both... send the mixer outputs into the 266 then out to the amps TYPICALLY we INSERT the compressor on a given channel, or channels and process that signal and send it back to the same channels...
Side-chaining uses the signal level of another input or an equalized version of the original input to control the compression level of the original signal. For sidechains that key off of external inputs, when the external signal is stronger, the compressor acts more strongly to reduce output gain. This is used by disc jockeys to lower the music volume automatically when speaking; in this example, the DJ's microphone signal is converted to line level signal and routed to a stereo compressor's sidechain input. The music level is routed through the stereo compressor so that whenever the DJ speaks, the compressor reduces the volume of the music, a process called ducking. The sidechain of a compressor that has EQ controls can be used to reduce the volume of signals that have a strong spectral content within the frequency range of interest. Such a compressor can be used as a de-esser, reducing the level of annoying vocal sibilance in the range of 6-9 kHz. A frequency-specific compressor can be assembled from a standard compressor and an equalizer by feeding a 6-9 kHz-boosted copy of the original signal into the side-chain input of the compressor. A de-esser helps reduce high frequencies that tend to overdrive preemphasized media (such as phonograph records and FM radio). Another use of the side-chain in music production serves to maintain a loud bass track, while still keeping the bass out of the way of the drum when the drum hits.
A stereo compressor without a sidechain can be used as a mono compressor with a sidechain. The key or sidechain signal is sent to the first (main) input of the stereo compressor while the signal that is to be compressed is routed into and out of the second channel of the compressor.
Found this online.
Dennis
Happy Easter!
I'm here all week. Tell your friends.
Next show is what... in 2 hours?
