DR260 vs XTi DSP; differences please...
I would like to know how much different the Driverack 260 processing is to the XTi DSP.
How different are the \"transfer functions\"?
If I plug in DR260 settings into the XTi's will the \"traces\" be the same?
The traces will NOT be the same for the same settings. The algorithms dbx uses are different than what Crown uses. This issue was actually the cause of the delay in getting out the Smaart interface for the DR260.
Again, I could make either one sound good. If you aren't pushing your system to the limits (not recommended) you should be fine with either way if you can handle the interface issues.
Mikey
I have found the speaker processor settings for the DR260, but none for the XTi's (non Harman speakers).
Since I don't have DR260 or SMARRT skills, I am wondering IF the DR260 settings inputted into the XTI's will give the the correct results; correct traces, phases and other information.
That means NO it won't be the same... I did however use the DR260 auto EQ data and used it as a starting point for the Xti amps processors...for what its worth... and got excellent results.
