SP4 tops & JBL 4520 subs
BruWar
4 Peavey SP4 Bi Amped Highs Peavey 900 amps
Mids QSC- 2450 - Mids (reloaded w-proline)
4 JBL 4520 Subs QSC - 2450
Just got my Driverack PA and want to know the best x-over or best setup.
Run every thing in Mono
http://www.dbxpro.com/forum/viewtopic.php?t=1081
http://www.dbxpro.com/forum/viewtopic.php?t=1080
you should have the basics, and the only difference is your running mono so use the left channel only and depending on how many amps you have for the subs you could lower the overall HPF of the subs to 40-45hz, and raise the HPF/LPF for the SP4/sub woofers to 100 hz LR 24.
