DBX Driverack PA
For some reason the Display Light doesn't work on the LCD Screen you can read everything on the screen but the screen itself doesn't lightup blue so it makes it hard to read... Any Idea if i need to replace a bulb or what i should do?? 3rd time i've taken this outta the box and i've had it a few years... the display light has never worked just curious what i can do?? HELP PLEASE!!!
  • DraDra Posts: 3,777
    Since it is obviously not under warranty, crack it open and make sure the ribbon cable to the front panel is attached. I'd unplug it and re-plug it back in to clean the contacts. Report back yay or nay.
    Good luck.
