Losing User presets on a 260
Does the 260 have a CMOS battery? I lost all of my user presets. The 260 has been sitting idle since September but I cranked it up over the weekend to get it ready for this year and all user presets are gone.
Gadget, do you know if the memory is volatile or not?
An IC, not a lithium battery, is used for retaining the preset information in that model. However, this IC should retain this information for many years without any issues.
If using firmware version 1.02 or higher you shouldn't have the checksum issue. If you do not receive the checksum error on the display, but do lose your programs, it may possibly be an issue with the display. Usually you will notice intermittent glitches with the display if this is the case. I would recommend having this device looked at by an authorized dbx service center or here at the main factory.
As Gadget said, it is a very good idea to backup your programs using DriveWare if possible.
Sorry for the inconvenience jwlussow.
