System Design
I just purchased the DriveRack PA+ and am using a Alesis MultiMix8Line mixer,2 - Crown CE4000 amps and the following speakers: 2 -Klipsch KP362,2 - Klipsch KP262, 2 - Klipsch KP480 and 2 - Behringer E1800X.I use this system to play music for my lakes 4th of July celebration with a SACD palyer as my source.Do I need another amp and how should I configure the system for optimum sound?
Low: (subs)
HPF 40hz BW18
LPF 120hz LR24
Mids: (10\")
HPF 120hz LR24
LPF out
Highs: (12\")
HPF 55 (or 60)hz BW18
Put the subs & 10's (together) in the center, splayed to cover the center. Put the 12's out on each side and just work out where the outer placements and at what angle they need to be.
If you want to run stereo, you'll need another amp. For that wide of a coverage, stereo is not practicle, unless to did a L-R-L, with the center speaker being the right and the outer speaker being left, and the subs being mono. (4 channels).
I recommend mono for you application.
I just recalled that you have the B'ger subs also. We don't recommend mixing subs, unless they are similar. Are the Klipsch 1 x 18 front loaded also? If yes, are they rated 400w cont, rms, program, peak? What?
I'll wait for your response.
Gadget, Dennis... care to make a guess here?
Dennis
Yes.
No.
http://forums.klipsch.com/forums/p/114472/1153707.aspx
Dennis
Why are you setting up a fullrange preset? That gives you no subs.
Gadget , Dennis...
Subs
XLS802 400w per speaker
CE4000 600w per speaker
What say you(s)?
I lean to a CE on the 12", a CE on subs and the XLS on the 10". Or is the XLS a better sub amp, even with the lower power?
I would also set up a custom preset, and without knowing a whole lot more about the tops I'd splay them for at least 100 degree coverage on each side...or set up in the middle and do a 360degree thing :idea:
I'd set up the way Dra said maybe too...
High Pass Filter (Low cut)
Low Pass Filter (High cut)
Filter order - Butterworth, Links Riley, Bessel, etc
18, 24, etc - db per octive drop off
