Driveracks availible none...????
Hi...
System setup:
480R - 480 - 480 - 442
I´ve set the first 480 as master and the following as 1 and 2
The terminators are in place as they should be, and everything is connected via the rj-45 with CAT5 awg 24.. all the green lights are lid..
in my MASTER 480 , i cannot see any availible driveracks anywhere...??
The 480R says \"box not found\" no matter what number i type on the keypad..??
My question is: Do i have to use speciel rj-45 cables..?? Should they be \"crossed\" in any way..??
Or what am i doing wrong...
Please help
Anders
System setup:
Please help
Anders
These connections do simply require standard straight through Cat5 cables.
These connections should be connected like this:
480R \"From dbx480P power Supply\"-->480P \"Link To dbx 480R Remote\".
480P \"Link To Network Master\"-->480 Master \"Controller In\".
480 Master \"Thru\"-->480 ID 1 \"Input RS485 Control Bus\".
480 ID 1 \"Thru\"-->442 ID 2 \"Input RS485 Control Bus\".
Have you tried configuring the other 480 device as the master?
