Limiter/compressor
Gmr112
Hi,
I'm using the DBX PX for a while now, and i'm quite satisfied with it.
I have setup the limiter, and that is working quite right now.
But still i am wondering if i can get some more out of the PX if i use the compressor option.
I use the PX with a Dynacord XA-2 set, only for DJ'ing, no live music.
(the dynacord set has his own x-over builtin his amps, so i send a full signal to the amps)
If the compressor is good to use, what settings should i try/look for? I read the manual and some stuff on internet about compressors, but i'm not sure what settings i should use.
If you do, minimal, minimal, minimal.
bad idea...
