Crossover setting
Hi
I’m new to this forum and to the DR260.
I’m the drummer and soundguy in a bluesrock band. I recently bought the DR260 to raise the bar quality vise on my rig.
I’m searching for the optimal crossover setting for my gear.
Tops: Yorkville TL315C. frequency range 50 – 18000, Amp:QSC 3402
Subs: Yorkville TS18, Frequency range 50 – 110, Amp XTI4000 in mono sum.
The Sups have a built in passive crossover in case of single amp setup, is this a problem?
Regards
Frode Ander
Regards
Frode Ander
May I direct you to the FAQ section just stocked full of useful tips and techniques.
http://www.dbxpro.com/forum/viewforum.php?f=60
and the setup and tuning thread:
http://www.dbxpro.com/forum/viewforum.php?f=61
But looking at the speakers you have plenty of power but I'd suggest a 100hz lopass/hipass using either LR24 or BW24. The subs I would hipass @ 40-45 hz BW 18
This will allow you to get under the subs internal hipass, and not work the 315's low end...
I see I have some reading to do.. (:
/Frode
