RTA Mic's
Hello all....
I just got my DriveRack PA yesterday and have been reading everything I can on it.
I've been reading the faq's and searched the posts but could not find the answer to my question regarding the RTA mic.
IS the dbx RTA mic any better than the Behringer 8000 RTA mic?
Thanks for your help.
Ken
Ken
Dennis
http://www.rationalacoustics.com/store/ ... a-420.html
I'll check out the SIA but since it is close to the price of the dbx would it be just as good as the dbx or better?
The frequecy chart is almost identical between the Behringer and the RTA-420..
Thanks again for your help.
Ken
Dennis
I think, till Dennis pointed to this mic and I don't know enough about it to say if it's better...that the Audix TR40 was the least expensive mic I would consider for use with an FFT type measurement system like SMAART... but with a 28 band sample that becomes a lot less of an issue if you knew what those specific frequencies were doing...
I'd definately opt for the best mic you can afford...either way...Dennis that mic looks interesting... know anything about it?
I've been trying some new techniques when performing with a new acoustic act I'm in, using a Condenser tube mic on vocals in small club venues. My other group has been using the Driverack PA for a couple years now and we've had great success with it. So I want to try to RTA each venue I go to to get the best sound I can..
So one of the first pieces I bought for my PA was the Driverack PA this week. I got lots to learn about it....lol...I've been reading like crazy...lol
Thank you guys for your help.
Ken
As I said muzicmaken... unless you tested a bunch and got a feel for the unit to unit consistency, the spec sheet doesn't mean squat...Look at speaker MFG's, they can make the spec sheet say anything they want...no standards... no real useful info...no testing by independent sources no useful info...
Currently, my test mic kit is two Audix TR40
Harry Brill, who is a Rational Acoustics instructor (SMAART) as well as a consultant has a bunch of the SIA mics in his kit (or did a year ago). He also has some more expensive mics but since SMAART is capable of 8 simultaneous inputs, a full kit of Earthworks would be a bit \"spendy\" although I am sure that is his goal.
Dennis
I saw on Harmony (I think) and thread about an app for the Iphone that is a FBT analyser. It uses the Iphone's mic. Supposed to be the bomb for people that don't have $1000's to spend on SMAART.
Looks interesting but... still only 1/3 octave, don't see any phase, or time...there are questions about the mic's \"flatness\" frequency response of some models is truncated @ 100hz and 8Khz...and you have to have an Iphone...I don't think so...That's Timmy P.. he used to hang here once in a while...
Dennis
Dennis
http://www.prosoundweb.com/site/topic/audio/P15/
article
Tuning A System At The Ultra Music Festival With EASERA SysTune
ken
• The RTA-420 microphone delivered equivalent performance to an Earthworks M30 for subwoofer work. The sensitivity is different but I detected no real difference in either magnitude or phase.
Where you will see a difference is in the high end response.
EASERA or SMAART is the next logical step after you have mastered AUTO EQ but want to do more. Keep combing through the various forums....there is a ton of information out there.
Dennis
Dennis
Dennis
I've not used any of the other audio apps, save for the frequency generator (which I got just to have it).
Thanks for stopping by.
If your main use is for identifying feedback frequencies (and I can relate to that), what does FFT accomplish that a RTA doesn't? And was I correct a few posts earlier in this thread about how to get two signal sources to the FFT app?
Dennis
Sorry to drag up an old thread. I was rooting around on my friend Google and came across this. I just wanted to clear up a few things about the SIA RTA-420 and maybe answer some other questions too.
The RTA-420 is the same mic as the dbx RTA-M and the Apex 220.
They are all pin 3 hot (not that it matters)
They are similar in quality to the ECM8000, as is the Audix TR40 (but they do have that coolness factor).
I currently carry 6 of them for use with Smaart. They are pretty much flat up to about 5KHz (this goes for every mic I've mentioned in the post so far). Above 5KHz is where they start to wander in response. Would you notice this in a recording? Likely not. Would you notice when EQing your PA, I doubt it. In fact they typically have a rise that peaks around 8-10KHz which might lead you to cut a bit in that range. Certainly not the end of the world. I tend to use my ear when EQing in that area regardless of what mic I'm using.
Sencore (TerraSonde) offered a matrix switcher with 4 unlabeled mics that are also the same exact mic. The ones I have measured were matched very closely obviously adding a great deal of cost.
Smaart 6 was not limited to 8 mics, but my preamp was.
Smaart 7 is not limited to 8 mics either, but my preamp still is.
Calibration files for individual mics will soon be available IF anyone is interested in making the mic look FLAT to Smaart. The cost is yet to be determined but will likely end up around $50. per mic. A user that NEEDS a flat response mic will likely drop the $600. plus on the Earthworks M30 which is fairly consistent mic to mic up to about 12KHz. If you want flat and consistent mic to mic above 12KHz you jump to the DPA 4007 or perhaps an ACO Pacific. There are others I'm sure.
There is a Smaart iPhone app that will be available pretty soon offered by Studio 6 Digital. They have teamed up with Rational Acoustics to basically offer the Spectrograph, and Transfer Function.
One more thing, an FFT can be a single channel RTA or a dual channel Transfer Function.
Have fun guys. Don't hesitate to email me if you have any questions. Google is your friend there.
Full disclosure ~ I am a dealer for Rational Acoustics Smaart 7 and I also sell the RTA-420, although my main line of work is as an audio mixer/ system tech.
So your saying the 420 is the SAME mic or that they are similar in that they all (the low budget mics) exhibit the same 5k and up anomalies?
I've been using the RTA-420s for over 2 years. I do not feel worried about them being knocked over or smashed. I have dropped my M30 more than once and the cost to repair once is enough to buy 3 of these mics. That being said, it's nice to have at least one more upper end mic to compare to. For the business of signal (time) alignment, and the majority of EQ, these inexpensive mics are a good choice. I feel strongly enough about that, that I'm selling them. There isn't a lot of money to be made with this product, but hopefully the point is made. Even the ECM8000 is good enough for most PA work, particularly if you only use one mic at a time. Considering the price tag, to pay any more is just so you won't get pointed at or made fun of by your friends. Of course you might have other reasons to avoid them.
Harry, we met at the Costa Mesa "earthquake" seminar. On the third day when you were setting your rig up in the theater, we discovered we had almost identical vintage 114dB calibrators. You may have moved on but I am still using mine.
Dennis
