Impedance
Dennis
So, if we know that an amplifier will put out 500W FTC per channel into 4 Ohms and 350W FTC per channel into 8 Ohms, how do we accurately calculate what that amplifier will put out into 16 Ohms.
No, this is not a quiz.
Dennis
Dennis
The output impedance of the amp is much less than the impedance of the speaker....
The damping factor Df = Zin / Zout tells you what Zout is.
Zout = Zin/Df.
If the damping factor Df = 200 and the loudspeaker impedance is Zin = 4 ohms, the output impedance of the amplifier is Zout = 4 / 200 = 0.02 ohms.
You see, there is no \"8 ohm amplifier\" on the market with a 8 ohm output impedance.
Then there is the line loss calculations that tell us the little if any of the current is actually getting to the speaker...
right...
So in reality there is no sense in attempting to calculate the amp power available without a degree in physics, and/or the garganutbrain computer from the 'Hitchhikers guide to the galaxy\"
right?
The power rating specs I listed above are for a QSC MX 1500 which I am using to power one JBL 2447 16 Ohm compression driver per side. Since I have dropped the XO point to 933Hz, the driver is using a lot more amplifier power than it did at a XO point of 1.2kHz. I would like to determine if I am using the correct size amp.
This is the first weekend I have had off in a month and I am sitting in front of my computer with a bottomless cup of coffee doing usless projects.
Dennis
I came across this article while surfing the web for answers today. It may partially answer your question...or may not help at all.
http://sound.westhost.com/project56.htm
Dennis
See, the thing is that As I said before there are so many factors...Frequency related impedance... back EMF, line resistance, amp damping factor...yada yada...They war about this all the time over at the PSW, and I guess if you wanted to, that might be the best place to ask...
At the last festival I did, the BSS Omnidrive output meters were hitting red a lot on the high outputs but the limiters kept the amplifiers from clipping.
All I planned to do today was transfer my JBL settings on the Omnidrive over to my DR260 and use them as a starting point to re-tune the system with the DriveRack. I then got sidetracked with my underpowered amplifier and decided I had better resolve that issue before setting up my computer and a measurement mic.
Dennis
http://www.loudspeakersplus.com/product ... c=joholre8
Check your PM in a bit...
Answer: The JBL is a challenge and there is a sense of accomplishment making it sound even half way good.
Dennis
I was assuming you were looking for solutions for the JBL's...My bad...
Dennis
