Driverack PA+ setup w/QSC CX254 and Crown XTi2000
Looking for setup with QSC part of system.
Crown XTi2000 - running (2) EV SX300E for highs/mids
QSC CX254 - running (2) EV Eliminator i Subs
System set to run in stereo.
This QSC is a 4-channel amp, setup bridged (1/3 left sub and 2/4 right sub) @ 500w per sub.
Need to find setup info for this QSC amp with the PA+ as there is nothing showing or any threads. Any help would be greatly appreciated!
Would RTA take care of this problem alone or still need setup info?
The subs are underpowered too, so here's what I'd suggest:
1. HPF for the sub @45 hz BW18
2. LPF for the subs @ 120hz BW24
3. HPF for the tops @ 120hz BW24
Next you want to set up the mic and go into the auto level where the output level of the 2 amps will be set...Note follow the prompts...mic 10-15 feet out
Next do the Auto EQ... Try a couple locations and see which sounds best
report back...
