X-over settings EV G118-EV Z-4
pierre
Hi, I'm mobile dj- party music
I need help with the crossover settings for the following setup:
2 subs EV G118 400 rms
amp Peavey PV2600 550 rms
2 tops EV Z-4 400 rms
amp Crown XLS 802 500 rms
Mixer Dateq Apollo
thanks from netherlands
Mixer Dateq Apollo
You're really underpowered on the subs and neither amp is spec'd to run bridged @ 4ohms.
You'll probably need to dial the tops amp back a bit to balance to the subs.
All things considered I'd set the subs to :
HPF 45hz (maybe 50hz) BW18
LPF 90hz (maybe 100hz) LR24
Tops:
HPF 90hz (maybe 100hz) LR24
Maybe someone else can clear up the mud.
IF that is an option then then setting from earlier would be changed a bit.
PS - More mud. There are those that would say you are perfectly powered (even a tad high). There is a valid arguement for both schools as it comes to killing speakers.
