PX with PRX-512Ms
I just purchased a PX for use with my system which is a Yamaha 24 MG24/14fx mixer into a pair of JBL PRX-512M mains and a pair of PRX-518subs.
Should I use the PRX-515 setting for the mains and leave as is?
Should I use the PRX-515 setting for the mains and make a slight adjustment (and what would that be?)
Or should I use the StMainSSub setting and what should my adjustments be?
Thanks in advance! As a noobie, I will likely have more questions later.
Also, if I end up being happy with the PX, I plan to purchase 2 more units to drive the 4 JBL EON15G2s I use for monitors.
Well, I guess you could use the 515 setting , but I'd raise the LPF/HPF of the sub top crossover 15's are typically capable of lower extension in a front loaded design, and the specs show that with the 515 showing 54 hz as the 3db down point and the 512 as 72 hz...So I'd set the HPF/LPF about 20 hz higher for the 512's. Then, if you haven't already, go to the READ ME FIRST BEFORE POSTING section and do some reading. The \"start here\" and FAQ section have extensive information and tips and tricks for getting the most out of your rig...
http://www.dbxpro.com/Forum/viewforum.php?f=61
http://www.dbxpro.com/Forum/viewforum.php?f=60
gadget
Yes, I just found the \"read me first before posting\" section right AFTER I posted :?
But I've printed out all the pertinent information and plan to spend a good portion of the rest of my Sunday devouring it.
Here's another quick question though, I hope you can answer: I plan on my first gig with the PX to be an outdoor show I'm doing in a couple of days. In order to make most efficient use of my time, what steps are recommend and/or can be skipped for an outdoor venue? And could I use ANY outdoor venue for my initial system setup? i.e., would my backyard be sufficient? or should I wait to set up the system in the large parking lot we will be performing in? (I'm also a bit concerned about showing up and then finding out that I won't be able to spend much time running loud pink noise through the system.)
