AFS 224
RoadRanger
I have two of these inline from my mixer's 4 monitor sends and the monitor amps. I have them set for -10dbu level so that they see enough signal to light the 0db light and occasionally flash the +10db lights as per the manual. These units are spec'd at +20dbu in and out, does setting the switch from +4dbu to -10dbu affect the +20dbu specs? Will the clip light flash at +20dbu or 14db below that now?
Also it's confusing as to the proper \"live \" usage for a portable PA. I need to reset the fixed filters every time I set up someplace different? I've been starting in \"fixed\" mode, ringing out the 12 (default) fixed filters then switching to \"live\" mode - is this correct? Sure would be nice if the manual told you how to actually use it in the real world ! I do seem to be getting a 6db+ improvement in GBF so I'm using them at least somewhat right I hope . The Sabine 1020+'s I have in my other system are a whole lot easier to use as they switch automatically to live mode after the fixed filters are \"used up\" - I'm basing my usage of the AFS224 on the MUCH better manual for the Sabine's.
I'd use them in mic channel inserts instead but I usually have 5 or 6 vocal mics set up and only 4 channels of AFS224 .
I don't know about the level selection affecting it's range. But, the hotter the signal that goes into them the better they work.
You do have to re-do the fixed filters at every venue, even if you move a monitor, or change a mic, you may have to.
I usually select as many as 18 filters for live. I start with speech and grab the first few, since they will usually be the widest problems, then switch to music-low, grab a few and so on. I usually get an extra 9db at least. I always set the lives to speech,m as they usually grab quicker and release after 5 secs.
I happen to have a extra AFS224 for sell. Absolute mint condition. Never been smoked on and has less than 50 hrs on it.
Hope that answered you questions.
http://www.dbxpro.com/Download/Quicksta ... _Guide.pdf
Still would like to know if the -10/+4 button effects the in and out clip levels?
