Designer 3.0 and 1260 v1.110
I have 4 1260's (firmware version 1.110) and recently installed Designer 3.0. I can see all the controllers but when I open 3 of 4 of them, the detail window seem to be stuck on \"Loading\". 1 of them actually loads and I can edit the settings.
There are no error messages anywhere. I am, however, running Vista (which I know is an error message in itself). I also connect wirelessly to the network. Router is open , no filtering or firewall.
Am I missing something?
Joel
Joel
Does each one work when connecting one at a time? If, so try adding one ZonePRO device at a time and see where the problem begins to occur.
Have you already assigned individual IP and node adresses to each ZonePRO?
