DBX223 XL and Mono Setup
clgales
I just purchased a system that consists of
2 Peavey SP2
2 Peavey SP118
Peavey CS 2000 until my CS4000 arrives
Carvin CS2444U
Peavey 215EQ
DBX223XL
The mixer is going mono out into the 215eq then into Side 1 of the DBX223xl.
I have side 1 low going into side 1 of the power amp and and side 2 high into side 2 of the power amp. The 223 is set for mono.
I then have side one of the power amp powering both SP118's in parallel and side 2 of the power amp powering both SP2's in parallel.
This way was recommended by a close friend but I did an experiment and noticed that if I put the 223 in Stereo and use side 1 low for the subs and side 1 high for the SP2 I gained some mid-range that was missing in the previous set up.
What is the correct way to set the 223 for my mono set up?
2 Peavey SP2
2 Peavey SP118
Carvin CS2444U
Peavey 215EQ
DBX223XL
In fine, opertate the x-over in stereo mono and just use one side.
So you are saying that Stereo and everything on one side would be the better way to go for my particular setup? Are there any additional recommendations for the setting I should use?
